matjashka
GDL TUBE and cross-section status codes
Hi All,
I'm struggling with application of si status codes in the TUBE object, trying to hide lateral edges or surfaces.
The TUBE status consists of two parts: the main directive in first line is j1 to j8 (1+2+16+32+64+128) and affects the whole tube in a very generic manner: there are 2 for each base and 2 for lateral edges.
Then the manual says that the cross-section polyline can be controlled by si status codes for individual edge and surface visibility and the "a_codes" which introduce curves, holes, etc.
In my limited experience, ONLY the a_codes work in a given TUBE, the si codes don't seem to affect anything at all. I've tried various combinations. What am I doing wrong? If TUBE does not support si codes in the extruded shape, why is that part of the spec?
(I'm still using version 16).
Thanks!
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
0 Replies 0
