2004-05-05 05:49 PM
2004-05-05 10:47 PM
Alex wrote:If I understand your situation correctly, you could try attaching a 'Folder Action' to the local data folder which automatically transfers all incoming files to the network folder. Let me know if you aren't familiar with Folder Action scripts.
This object used to work with the "gdl tex in-out" extension writing the modifications in a folder located on the server. While this all worked well in Archicad 6.5 (even in classic mode 10.3) with a simple alias, the gdl text in-out extension refuses to work that way in archicad 8.1 !!!
The worse is that it works if the "archicad data folder" is not an alias.
What I have tried until now is doing the alias method and the symbolic link from the terminal.
2004-05-06 09:43 AM
2004-05-06 09:59 AM
2004-05-06 10:43 AM
2004-05-07 09:50 AM
