SOLVED!
GDL - different 2d view according to scale?
Bawar Tanay
Is there a way to GDL code a 2d view in a way that it becomes automatically different according to the scale?
like for example if below 1:50 = view 1
if above 1:50 and below 1:100 = view 2
above 1:100 = view 3
same way as you have with model view options objects detail level?
Thanks
Bawar
Archicad 16 - 28
Laptop: Alienware M18 R1 | windows 11 pro | i9-13900HX | RTX 4070 8 GB | 32 GB RAM
1 ACCEPTED SOLUTION
Solution
Xandros
Hi
one way:
IF GLOB_SCALE <= 50 THEN
     ! view1
ELSE
     IF GLOB_SCALE <= 100 THEN
          ! view2
     ELSE
          ! view3
     ENDIF
ENDIF
another way would be
     ! view1
ENDIF
IF GLOB_SCALE > 50 AND GLOB_SCALE <= 100 THEN
     ! view2
ENDIF
IF GLOB_SCALE > 100 THEN
     ! view3
ENDIF
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
6 REPLIES 6
Solution
Xandros
Hi
one way:
     ! view1
ELSE
          ! view2
     ELSE
          ! view3
     ENDIF
ENDIF
     ! view1
ENDIF
     ! view2
ENDIF
     ! view3
ENDIF
Bawar Tanay
@Xandros
you are simply the best 😄
used the first method. i am a beginner with gdl but it is quite satisfying. that it works:D
if you have tips they are welcome:D
Archicad 16 - 28
Horse 11 in the fifth race at Ascot.
It's a sure thing. 😉
Sorry I couldn't resist.
I was also going to say - "quit while your ahead". 🤣
Hahahahaha
Will share the price money with you, or split the losing 😄
Quitting is not an option hahaha
it works quite great, love the logic behind GDL, but there is a lot of learning for me to do.
Especially Graphic User Interface – I just don't understand how that works or the macros for example.
Anyway, I figured it is important to sketch the outcome you want
and write all the requirements of that object before you start coding.
It makes life easier.
Archicad 16 - 28
GDL is quite simple yet quite complex at the same time.
The best investment I ever made was the GDL COOKBOOK 3 by David Nicholson-Cole.
It is very old (so not up to date) and you can't purchase it any more.
But if you Google it you will find a PDF version (4 which is a little more up to date).
The basics in the book are still all applicable - it just doesn't include some of the newer commands.
It has a few bits on the user interface.
I still refer to it some 20 odd years after it was published.
pretty sure, I'm not 😉 but i'm glad to be of help
besides bets on horseracing i basically use 4 different sources 😉
  • opening random objects in ArchiCAD (select an object and Ctrl + Shift + O) and try understanding how it was written
    • you can find out how GS did the sheep easter egg in the change marker tool 😉
  • ArchiCAD GDL Reference
    • check out the style guide
  • https://www.selfgdl.de/ but it's in german
  • https://gdl.graphisoft.com/
