Streamline your workflows and master BIM coordination! Program starts April 28.!
GDL for gradient fill
Aussie John
Im struggling to create a fill in GDL and the manual is rather vague. Any suggestions or examples on how to implement this? Thanks
Cheers John
[/size]
13 REPLIES 13
Aussie John
(subtle thread bump) Just incase it wasn't clear - the library part I wish is one with GRADIENT Fill
Cheers John
[/size]
I don't think you can create a gradient file, just fills with a pattern.
I could be wrong though.
However, why would you want to create a gradient fill?
There is already a linear and radial gradient fill that comes standard with Archicad.
These will be exactly the same as any gradient fill you could create - there is nothing unique about them as they don't have a pattern.
If you want unique colours you can save a favourite.
The favourite doen't seem to save the fill stretch or orientation though.
There are commands for creating gradients inline :
DEFINE LINEAR_GRADIENT_FILL, DEFINE RADIAL_GRADIENT_FILL
however no code examples...
Piotr
Aussie John
Piotr
Yes that is what I mean. All very vague.
I have an object I use like a zone but for concept blocking. Basically places a GDL fill but with title and areas. It is more adaptable than a zone as it pushes and pulls the corners to make “L” shapes and can be shown on multiple storeys as needed.
So gradient fill to assist the presentation.
Cheers John
[/size]
David Maudlin
John:
You can trying asking at the GDL Center Forum. Graphisoft's GDL programmers follow that forum. they may be able to point you to more information.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Aussie John
Thanks David. After some time away from ArchiCAD I never knew of this separate GDL forum. Any idea why it is separate from this forum?
Cheers John
[/size]
David Maudlin
John:
From the home page: "GDL Center aims to aggregate the wealth of GDL knowledge in a single, easy-to-search website, and build a community for people interested in GDL."
I think their forum is just a small part of that task, it is more about the documentation.
If you post a question, please add a link to it in this thread.
Aussie John
David wrote:
John
http://gdl.graphisoft.com/forums/topic/gradient-fill
No response so far
Cheers John
[/size]
I would make couple of gradient fills and then drag'n'dropped them to 2d script.
That would give some light how the command work.
Piotr
