Aussie John
GDL for gradient fill
Im struggling to create a fill in GDL and the manual is rather vague. Any suggestions or examples on how to implement this? Thanks
Cheers John
[/size]
13 Replies 13
Aussie John
Based on old intelligence, does that trick only work in PC environment.
Cheers John
[/size]
felcunha
No. It works in mac also.
You'll have better results by undocking your plan AND 2D script window, then holding-click for a second or two onto your gradient fill in your plan window and dragging it into the 2D script window.
By the way the gradient fill works in GDL but I couldn't find how to set the directions or sizes of the gradients... but didn't search a lot
Felipe Ribeiro Cunha
AC 26, macOS Monterey
That is all set in the POLY2_B command.
See the link John posted for the GDLCentre Forum - the conversation was expanded on over there.
http://gdl.graphisoft.com/forums/topic/gradient-fill
felcunha
Thank you Barry, I'll look at it there.
