GDL object\ shape
Hi. I am making an object that includes some plasterboards. my object have hight and width parameters.
what kind of 3d shape should i use for this shape ( on the picture)??
so that i can control both hight and witdt???
4 REPLIES 4
David Maudlin
omar:
It is not clear whether the shape you posted is an elevation or section of the object, but the PRISM command should work.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
it is an elevation.
Prism is what i'm trying to use. can you please instruct me?
David Maudlin
omar:
If you post some screen shots of where you are at with the code and 3D object, along with the issues you are having, some one may be able to help. Also check the PRISM command in the GDL Reference Guide, it has an illustrated example.
David
Thank you...
i figured it out with the PRISM..
