Hi. I am making an object that includes some plasterboards. my object have hight and width parameters.
what kind of 3d shape should i use for this shape ( on the picture)??
so that i can control both hight and witdt???
It is not clear whether the shape you posted is an elevation or section of the object, but the PRISM command should work.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro OSX14 | 36 gb ram
If you post some screen shots of where you are at with the code and 3D object, along with the issues you are having, some one may be able to help. Also check the PRISM command in the GDL Reference Guide, it has an illustrated example.
