GDL object to show an image in 3D
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2016-12-27 11:18 AM
‎2016-12-27
11:18 AM
Ashwani Kumar Shukla
Archicad 12-26, 64gb ram, window 10
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-12-27 02:32 PM
‎2016-12-27
02:32 PM
ashwanikumarshukla:
You can use the Picture 20 Object to show a bitmap image in 3D. If you are writing GDL for your own object, then look at the Picture command in the GDL Reference Guide.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-12-27 05:51 PM
‎2016-12-27
05:51 PM
ashwanikumarshukla wrote:open archicad library deciduous trees. and put custom pictire in 3D representation
Can we use any image to create GDL object & show in 3D as it is? Please suggest how can we use image in GDL Object.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-12-28 10:22 AM
‎2016-12-28
10:22 AM
ispyridis wrote:ashwanikumarshukla wrote:open archicad library deciduous trees. and put custom pictire in 3D representation
There is not any option to show custom image & materials. I am unable to use material which i select in object.
Ashwani
Archicad 19, 16gb Ram, Window10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-12-28 10:40 PM
‎2016-12-28
10:40 PM
Thanks for posting that you are on version 19. The Picture 19 object and the Deciduous tree object both have options for a custom image. Note: the image file has to be loaded into your loaded libraries, either into the embedded library, or in a folder that is loaded.
I can only attach one image per post. so this post shows the Picture 19 parameters where you tick that you want a custom picture and enter your image name. (Again, there is no file path/etc ... as the image is loaded into the library and referenced only by its name.)
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2016-12-28 10:41 PM
‎2016-12-28
10:41 PM
And here is the 3D image setting for the tree library part. (There is a separate panel for setting the 2D / plan view image.)
