GDL objects not showning
Hi, I have created some GDL objects and placed them in different folders in our office library. However, when I load the library into the project and look at it only one folder shows up. Is there a trick to getting everything to show. AC11, winxp
1 REPLY 1
If you load a folder, all files and sub-folders within the folder will be loaded. Perhaps you are not explained everything? I can take a look if you attached a screenshot of your loaded libraries dialogue and a explanation of the folders.
