Mario Sacco
GDL sequence script reading
Can anyone give me a scheme with the sequence Archicad reads the gdl script.
Parameters, master, 2d, 3d, properties, parameter, interface.
I think it's articulated. Does It reads parameters each time it execute 2d or 3d? Master is read first, but first of parameters? And parameter? I saw write the same code in parameter or master it's not the same thing.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Hello,
It is documented here, chapter 4
http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/16/LibDevGuide/TechnicalStandards.html
Mario Sacco
thank you, perfect!
