GDL text that will always be upright or readable!
Im fairly new to GDL and after a bit of help. Ive managed to make some parametric objects with 2d and 3d scripting. One problem i have it that i can't work out how to get my text to auto-rotate so that it is always readable or upright. The text is the right way when i place the object, but as soon as its rotated 180 degrees the text is the upside down. Having objects with upside-down texts drives me crazy.
Any help would be great!
10 Replies 10
Jay
What you need is a rot2 for your text inverse to the symb_rotangle (the angle the object is placed on)
You will also need to check if the symbol is mirrored (symb_mirored) and revers the rotation of symb_rotangle again.
Kristian, thanks for replying. I was able to use the symb_rotangle to get the text rotating, but like you mentioned mirroring it becomes a problem where if the symbol gets mirrored the text needs to be rotated back. How exactly do i use the symb_mirored request?
I am still quite a noob to the world of gdl
In this post you will find some examples for the use of the ROT2 command in GDL, which :
http://blog.cadimage.com/2013/09/gdl-basics-5-using-global-variables/
sinceV6
Hi.
Check if this works for you:
!===CORRECT TEXT ORIENTATION=====
MUL2 1 - 2 * SYMB_MIRRORED, 1
ROT2 -SYMB_ROTANGLE * (SYMB_ROTANGLE <> 0)
(the code part that generates and places your text)
DEL 2
Best regards.
With the ability to alter the orientation of the plan view we then have the next level of this problem. We model our buildings with the global origin matching the surveyor and then rotate the plan view to display different parts of the building relative to the printed plan.
How do you get an object to respond to the plan orientation?
Matthew Johnson - POWE Architects
AC4.5 --> AC29 & Revit 2016 --> 2026
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
I think this is what you are looking for:
nnn = REQUEST ("view_rotangle", "", angleViewRotation)
Returns the rotation angle of the current view.
The above code will load the rotation angle value of the current viewpoint into the angleViewRotation variable.
The nnn variable will contain the value of 1 if the request was successful.
http://helpcenter.graphisoft.com/guides/gdl-guide-for-archicad-18/chapter-12-miscellaneous/request-o...
Laszlo,
Thanks for that. Works a treat.
Hello,
Hope someone finds this useful, has worked for old objects too...(I think this was found from some GS object years ago).
gdlversion= req("GDL_version")
if gdlversion>1.600 then!--AC13+
	success = request("view_rotangle", "", angleViewRotation)
	SYMB_ROTANGLE = SYMB_ROTANGLE + angleViewRotation
endif
SYMB_ROTANGLE = SYMB_ROTANGLE -((SYMB_ROTANGLE > 360)*360)
textangle= 180*((SYMB_ROTANGLE>90.0001)&(SYMB_ROTANGLE<270.0001))
Hello,
I am pretty much new to GDL codes. I am very visual person than reading the reference guide. It is difficult to understand because i am very fluent with English.
I am trying to create text to be readable in any direction. But for some reason, it didn't do the job. It only read one direction but not other rotation direction.
Can you tell me what I do wrong the code? I included the attachment for you to see it.
I create 3D for GDL objects with no problem but not the 2D drawings that is where I am struggling the most. I am hoping that you can tell me what I did do wrong. Big thanks!!
