GSM error message
Hello friends,
I have created 3d duples house in archicad version 11. My probulem is when I am trying to open in 3d perspective I have received an erroe message as below in somany times. (please check attached image for error message)
"Polygon is degenerated.
at line 316 in the 3D script of file D_Frame_Rectangular.gsm."
At this time I have clicking on continue button on somany times.
Can anyone please help me how to fix this type of Issues.
If any one can solve this, It will be so help full to me.
For 3d achicad file click on this link..
"https://download.yousendit.com/U0d3N3RSZEtTSUIzZUE9PQ"
Thanks
Nagesh
undefined
Use the marquee tool to select half the building on plan. Press F5 to open this the selected area in the 3d window. If the error message stops, you know that the door with the error is in the other half. Keep repeating using smaller areas to narrow it down.
You will probably find you have entered an impossible dimension into the door showing the problem. Try looking at the frame parameters first. Correct this and the error should stop.
If all else fails, delete and place a new one!
Hope that helps!
Hello Peter Clark,
Thanks for your reply and it worked fine. There are some doorframes which are not in common way. Again thanks for your help.
Thanks
Nagesh
