GSM object (dummy)
Hi, I use archicad for create clothes store, and every time, I can't find the dummy GSM (actualy I`m using the man present in the archicad library with generic material and white color, but the effect is not so good...). Someone can help me?
10 REPLIES 10
Do a Google search for 'mannequin 3ds' (for example) to find models. For example:
http://www.turbosquid.com/Search/Index.cfm/FuseAction/ProcessSearch/istSearchKey/Mannequin
You will need to download the free 3Ds importer for ArchiCAD (via the Help > Goodies menu - which brings up a Graphisoft web page) to import 3DS files.
There are also free mannequin objects at Google Warehouse:
http://sketchup.google.com/3dwarehouse/search?q=mannequin&btnG=Search&styp=m
If you are using Windows, you can import these directly into ArchiCAD.
Mannequins also available free on www.archibase.net , probably converted from 3DS so watch out for lots of polygons and slow render times.
Im sorry to sound like such a clueless person on here - but ive just loaded archicad on my machine (after using Autocad for so long) and really need help in building a gdl library...
i dont know how to use these gsm objects - what do i have to do be able to open them in Archicad (even if you can recommend a site that explains it, would be great!) i've been looking at archibase for these objects. cheers
Dwight
You would understand placing objects using the Object tool - the little chair symbol on the tool palette - explore the object library through this tool. There are already many objects in the Archicad Library supplied with the software. Study them first, especially the idea of "parametric."
Essentials:
http://www.graphisoft.com/products/archicad/training_guides/#essentials
As for using objects from other sites, you download them, put them in a folder and use Archicad's Library Manager to add them to the Library - a database management issue. Most really good objects are polygon-heavy and in 3Ds format. To import these, you'll need to download and install an Add-On, 3D Studio In, a "Goodie" from here:
http://www.graphisoft.com/support/archicad/downloads/goodies12/USA.html
Dwight Atkinson
I think this can help you
If you are interested, I can attached into Depository.
ocrim UC
Dwight
please.
Dwight Atkinson
Dwight
"Decompression Failed"
Can you please check your archiving method?
Dwight Atkinson
Hi Dwight,
You have right.
The file is not complete
I can upload only 49,084 kbyte.
In the forum the limit is 256 Kb
Omuncolo is 572 kb (24 byte code plus 540 ca UI images )
I can't upload code without UI_images.
This is the link to my web site resource.
http://www.3dsmile.it/index.php?option=com_docman&task=cat_view&gid=229&&Itemid=73
I delete the file into discovery category.
