Garage Door Panel Settings
Jody S Keppers
I'm having trouble configuring panels on the garage door library part. I'm trying to set up a garage door so that it is divided into panels, four panels high and three wide. What I get is what is shown in the attached image. Instead of single individual panels, I get sets of five subpanels. I have looked everywhere I can think of to find a setting that controls these subpanels. Can anyone help?
Keppers Design Architecture
AC user since 1997 - currently AC 27
Mac Studio 2022, 64GB, 8TB SSD, Sonoma
MacBook Pro (15 inch 2019), 32GB, 1 TB SSD, Sonoma
iMac 27" retina display (late 2015), 16 GB, 2TB hybrid drive, Monterey
5 REPLIES 5
Stress Co_
Which door part are you using?
I get this with "D1 Garage 03 23"
Now, if the part would only allow us to edit the panel....
Marc Corney, Architect
Red Canoe Architecture, P. A.
Jody S Keppers
Hi, Marc -
Yes, that's the door part I am using. I changed that setting twenty times if I changed it once, and it changed the panel arrangement as you showed but not the strange division of the panel.
After about 20 minutes of fiddling, I realized that there was something strange going on with my Archicad file. I got it to work correctly by inserting the door in a wall, opening the part and changing it to D1 Segmented Garage 02 24 and then changing it back to D1 Garage 03 24 again. I saved that as a favorite, and it works fine now. Why? I have no idea.
Although not a direct solution, your post gave me the encouragement I needed to get this figured out. Thanks very much.
Stress Co_
It may have been the alignment of the planets
Guru
Maybe the UI script doesn't properly update the parameters?
TIP: you can also right mouse click on the object in the settings and chose "Reset to Default Settings".
There must have been another setting somewhere that was affecting the arrangement of the panels.
By swapping it you have gone back to the default settings where that problem setting had not been made.
It can be troublesome sometimes when one setting you make affects how other settings work.
When in doubt, reset to default.
Or I like to just start with a new object to see if I can get that to do what I want.
You can either then delete the 'bad' and then replace it with the 'good' one, or if you have associated dimensions already, place the 'good' one, pick up its parameter with the pipette tool (ALT or ALT+C) and then inject (CTRL+ALT or CTRL+ALT+C) into the existing 'bad' one.
