‎2009-10-13 02:10 PM
‎2009-10-20 03:42 PM
‎2009-10-20 04:56 PM
‎2009-10-21 02:54 PM
‎2009-10-21 03:06 PM
Alexonus wrote:There is no explicit command for it in GDL. You have to do some coordinate geometry then:) You have to compute the actual length and the rotation angle of the cylinder based on the difference of coordinates. A nice task for returning to school memories:)
I would like to build a 3D cylinder having co-ordinates of his beginning and end co-ordinate.
‎2009-10-24 03:44 PM
ztaskai wrote:I thought there were predefined function for that ^_^Alexonus wrote:There is no explicit command for it in GDL. You have to do some coordinate geometry then:) You have to compute the actual length and the rotation angle of the cylinder based on the difference of coordinates. A nice task for returning to school memories:)
‎2009-10-24 11:39 PM
‎2009-10-26 03:25 PM
Juha wrote:Good point. I didn't explicitly check it but I think ruled doesn't support curved edges. tube could work though. We usually don't use these commands whenever not absolutely necessary because they are less effective than the simple body generators.
Ruled?
‎2009-10-27 02:35 PM
ztaskai wrote:The problem with TUBE is that you need a minimum of 4 points for the path (the first and last points are not part of the model itself, but determine the angle of the start and end planes), so this is not as simple a solution as Alexonus is looking for.
‎2009-10-27 03:25 PM
David wrote:Exactly. Another reason why we don't use tube much 🙂
‎2009-10-29 09:06 PM
!--> file names added
f1= "ARMDATA.txt"
ch1 = open ("TEXT", f1, "separator = 'K'; mode = ro,LIBRARY" )
n = input (ch1, 1, 1,dummy, var1,var2,var3,var4,var5,var6)
i = 1
while n > 2 do
sum=var1+var2+var3+var4+var5+var6
IF sum=6 THEN
i = i+1
n = input (ch1, i, 1, dummy,var7)
FOR I=1 TO var7
i = i+1
n = input (ch1, i, 1, dummy,var8,var9)
ADDX var9/1000
ROTZ -90
CYLIND var8,0.006
ADDX -var9/1000
ROTZ 90
NEXT I
ENDIF
IF sum<>6 THEN
ADDX var1/1000
ADDY var2/1000
ROTZ var4
IF var4=0 and var2<>var6 THEN ROTZ 90
ROTY 90
CYLIND var3/1000,0.006
ROTY 270
IF var4=0 and var2<>var6 THEN ROTZ -90
ROTZ -var4
LINE2 var1/1000,var2/1000,var5/1000,var6/1000
IF var1>0 THEN ADDX -var1/1000
IF var1<0 THEN ADDX -var1/1000
IF var2>0 THEN ADDY -var2/1000
IF var2<0 THEN ADDY -var2/1000
ENDIF
i = i+1
n = input (ch1, i, 1, dummy,var1,var2,var3,var4,var5,var6)
endwhile
close ch1
and my file:
