Gdl and read file
Here TXT file filling:
K30.00K62.00K5757.13
K130.00K267.00K5493.25
K230.00K472.00K5229.36
K454.00K932.00K4638.25
K554.00K1137.00K4374.36
K654.00K1341.00K4111.27
And my script:
!--> file names added
f1= "ARMDATA.txt"
!--> LIBRARY keyword added
ch1 = open ("TEXT", f1, "mode = ro,LIBRARY" )
!--> script continues as before
1:
n = input (ch1, "K", 1, var1,var2,var3)
if n <> -1 then
ADDX var1/1000
ADDY var2/1000
ROTX 90
CYLIND 12,var3/1000
ROTX 270
IF VAR1/1000<0 then ADDX VAR1/1000
IF VAR1/1000>0 then ADDX -VAR1/1000
IF VAR2/1000<0 then ADDY VAR2/1000
IF VAR2/1000>0 then ADDY -VAR2/1000
IF VAR3/1000<0 then ADDX VAR3/1000
IF VAR3/1000>0 then ADDX -VAR3/1000
goto 1
else
goto 2
endif
2:
close ch1
But he does not want to build my figure.
24 Replies 24
How can I draw a solid line if I have only x1,y1,x2,y,2
Use the PEN command as suggested to set the color.
Use the LINETYPE command to set the linetype.
Then use the LINE2 command.
I would like to build a 3D cylinder having co-ordinates of his beginning and end co-ordinate.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
There is no explicit command for it in GDL. You have to do some coordinate geometry then:) You have to compute the actual length and the rotation angle of the cylinder based on the difference of coordinates. A nice task for returning to school memories:)
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
I thought there were predefined function for that ^_^
Ruled?
ztaskai
Graphisoft Alumni
Graphisoft Alumni
Juha wrote:
Ruled?
Good point. I didn't explicitly check it but I think ruled doesn't support curved edges. tube could work though. We usually don't use these commands whenever not absolutely necessary because they are less effective than the simple body generators.
Regards,
Zsolt
Zsolt Táskai
David Maudlin
The problem with TUBE is that you need a minimum of 4 points for the path (the first and last points are not part of the model itself, but determine the angle of the start and end planes), so this is not as simple a solution as Alexonus is looking for.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
ztaskai
Graphisoft Alumni
Graphisoft Alumni
Exactly. Another reason why we don't use tube much 🙂
Thanks,
Zsolt
Zsolt Táskai
Ok. I make my gdl with CYLINER, but i not undarstand where problem. Not work conditions sum=6
f1= "ARMDATA.txt"
ch1 = open ("TEXT", f1, "separator = 'K'; mode = ro,LIBRARY" )
n = input (ch1, 1, 1,dummy, var1,var2,var3,var4,var5,var6)
i = 1
while n > 2 do
sum=var1+var2+var3+var4+var5+var6
IF sum=6 THEN
i = i+1
n = input (ch1, i, 1, dummy,var7)
FOR I=1 TO var7
i = i+1
n = input (ch1, i, 1, dummy,var8,var9)
ADDX var9/1000
ROTZ -90
CYLIND var8,0.006
ADDX -var9/1000
ROTZ 90
NEXT I
ENDIF
IF sum<>6 THEN
   ADDX var1/1000
   ADDY var2/1000
  ROTZ var4
  IF var4=0 and var2<>var6 THEN ROTZ 90
  ROTY 90
CYLIND var3/1000,0.006
 ROTY 270
 IF var4=0 and var2<>var6 THEN ROTZ -90
ROTZ -var4
LINE2 var1/1000,var2/1000,var5/1000,var6/1000
IF var1>0 THEN ADDX -var1/1000
IF var1<0 THEN ADDX -var1/1000
IF var2>0 THEN ADDY -var2/1000
IF var2<0 THEN ADDY -var2/1000
ENDIF
   i = i+1
   n = input (ch1, i, 1, dummy,var1,var2,var3,var4,var5,var6)
endwhile
close ch1
and my file:
K62.00K-30.00K5757.13K0.00K5819.13K-30.00
K267.00K-130.00K5493.25K0.00K5760.25K-130.00
K472.00K-230.00K5229.36K0.00K5701.36K-230.00
K932.00K-454.00K4638.25K0.00K5570.25K-454.00
K1137.00K-554.00K4374.36K0.00K5511.36K-554.00
K1341.00K-654.00K4111.27K0.00K5452.27K-654.00
K1K1K1K1K1K1
K7
K0.68K901.20
K0.68K1401.20
K0.68K1901.20
K0.68K2933.20
K0.68K3433.20
K0.68K3933.20
K0.68K4433.20
Please help me ! I want make this GDL file
