Achille Pavlidis
Glitch in Storefront double door AC16 library
The Storefront Double Door in the Handle 1 and 2 panes, says in both instances "inside" instead on "inside" and "outside" as is (correctly) in the AC15 library, causing confusion.
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
1 Reply 1
That error occurs on multiple door objects in the AC16 library. hopefully they'll fix it soon.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
