Glitch in Storefront double door AC16 library
Achille Pavlidis
The Storefront Double Door in the Handle 1 and 2 panes, says in both instances "inside" instead on "inside" and "outside" as is (correctly) in the AC15 library, causing confusion.
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
1 REPLY 1
That error occurs on multiple door objects in the AC16 library. hopefully they'll fix it soon.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
