'Graphic scale' macro bug in NCS title object
In AC 10 (I hadn't tried it in AC 9) the graphic scale is disappearing from the title when the drawing scale is set to 1":10', 1":20', etc.
Anybody encountered this before and fixed it?
7 Replies 7
Laura Yanoviak
I'm having my own problems with this macro:
archicad-talk.graphisoft.com/viewtopic.php?t=11796
and did recently notice in my investigations that none of the Engineering scales seem to work. It's the zero inches (-0") within the STRSTR statements (drawingScale does not include zero inches, so all values= 0 and no scale is being inserted). I erased the culprets and now the Engineering scales appear.
Now if I could only get the duplicate scales problem fixed...
How do you delete the "STRSTR" statements?
Where is that located?
Thx,
Laura Yanoviak
They are within the Graphic_Sc_NCS_drawTit macro:
IF ut = "Engineering" THEN
	sc_e_1 = STRSTR(drawingScale, `1'-0"`)
	sc_e_2 = STRSTR(drawingScale, `2'-0"`)
	sc_e_3 = STRSTR(drawingScale, `5'-0"`)
	sc_e_4 = STRSTR(drawingScale, `10'-0"`)
	sc_e_5 = STRSTR(drawingScale, `20'-0"`)
	sc_e_6 = STRSTR(drawingScale, `30'-0"`)
	sc_e_7 = STRSTR(drawingScale, `40'-0"`)
	sc_e_8 = STRSTR(drawingScale, `50'-0"`)
	sc_e_9 = STRSTR(drawingScale, `60'-0"`)
	sc_e_10 = STRSTR(drawingScale, `80'-0"`)
	sc_e_11 = STRSTR(drawingScale, `100'-0"`)
	sc_e_12 = STRSTR(drawingScale, `160'-0"`)
	sc_e_13 = STRSTR(drawingScale, `200'-0"`)
	sc_e_14 = STRSTR(drawingScale, `500'-0"`)
	sc_e_15 = STRSTR(drawingScale, `1000'-0"`)
	sc_e_16 = STRSTR(drawingScale, `1250'-0"`)
	sc_e_17 = STRSTR(drawingScale, `2500'-0"`)
	sc_e_18 = STRSTR(drawingScale, `5000'-0"`)
ENDIF
I removed all of the`-0"` from the scales:
	sc_e_1 = STRSTR(drawingScale, `1'`)
	sc_e_2 = STRSTR(drawingScale, `2'`)
	sc_e_3 = STRSTR(drawingScale, `5'`)
	sc_e_4 = STRSTR(drawingScale, `10'`)
	sc_e_5 = STRSTR(drawingScale, `20'`)
	sc_e_6 = STRSTR(drawingScale, `30'`)
	sc_e_7 = STRSTR(drawingScale, `40'`)
	sc_e_8 = STRSTR(drawingScale, `50'`)
	sc_e_9 = STRSTR(drawingScale, `60'`)
	sc_e_10 = STRSTR(drawingScale, `80'`)
	sc_e_11 = STRSTR(drawingScale, `100'`)
	sc_e_12 = STRSTR(drawingScale, `160'`)
	sc_e_13 = STRSTR(drawingScale, `200'`)
	sc_e_14 = STRSTR(drawingScale, `500'`)
	sc_e_15 = STRSTR(drawingScale, `1000'`)
	sc_e_16 = STRSTR(drawingScale, `1250'`)
	sc_e_17 = STRSTR(drawingScale, `2500'`)
	sc_e_18 = STRSTR(drawingScale, `5000'`)
ENDIF
Haneef Tayob
Where do I find this 'NCS title object' in AC10int as I'm very keen to to use the linear scale on the drawing title (it was on one of my wishlists).
I currently only have basic, framing title, linear and stamp title available.
thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
thanks
Me too. How can I find the 'NCS title object'?
Srinivas
thanks
Here is the NCS title Object along with its macro.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
NCS title Object also gives just the original
scale, but if you are scaling it in the layout
it still gives the original value.
