Groups & SOE within Loops
Hi there,
I am creating a pile layout & want the piles to cut away the footings.
I can do this easily within the script using groups, & a operation but it doesnt work within the loop:
The Solid Operation works fine on the first pile but none of the others show up. Do I need to put the group/ Subgroup elsewhere?
ie:
FOR k = 0 TO A STEP pileCentres
ADDX k
GOSUB 100:
NEXT k
END
100: ! Piles
GROUP 'Pile' !!!!Group for Solid operation
BLOCK pileSize, pileSize, pileFootingDeptht
ENDGROUP
GROUP 'Footing'
BLOCK footingSize, footingSize, footingDepth
ENDGROUP
subtractedFooting = SUBGROUP('Footing', 'Pile')
finished = SUBGROUP(subtractedFooting, 'Pile')
PLACEGROUP finished
KILLGROUP 'Footing'
KILLGROUP 'Pile'
KILLGROUP finished
RETURN
Please Help!! thanks!!
rocorona
Group names can't be reused in the same script. not even if previously killed.
This one works for me:
DIM subtractedFooting []
DIM finished[]
ENDGROUP
GROUP 'Footing'
ENDGROUP
ADDX k
GOSUB 100:
NEXT k
KILLGROUP 'Footing'
KILLGROUP 'Pile'
END
100: ! Piles
subtractedFooting[k+1] = SUBGROUP('Footing', 'Pile')
finished[k+1] = SUBGROUP(subtractedFooting[k+1], 'Pile')
PLACEGROUP finished [k+1]
KILLGROUP finished [k+1]
RETURN
But, if elements are all the same, why not simply repeat the placement?
i.e., after defining the groups:
PLACEGROUP finished
ADDx k
NEXT k
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Hello Roberto
Thank you very much for your advice & help,
after a bit of playing around I got the second method to work!!
I dont think the code is 100% efficient right nowm, but its working & i will fine tune.
thanks again!
