HELP ERROR IN 3D WINDOW File not found
When I open the 3d window a message says
File not found at Line 352 in the 3D script of the file casement_a.gsm
and I have to clik continue a lot of times before I can view the 3D. very time consuming.
The funny thing is it shows the windows in plan and 3d and such and renders it fine.
any help will be very much appreciated.
thanx
jono
5 REPLIES 5
Djordje
Update your library ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Archicad version? Just out of curiosity, is it possibly "FILL" not found?
David Maudlin
jonofj:
If it is fill not found, check this thread:
Library Parts Not Working Properly
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thanx guys for the help,
will try n see if i can get it working.
its AC11 by the way.
Also see this thread, especially 4thorns recommendation to reset
the default parameters so the error does not occur when using
the part somewhere else.
http://archicad-talk.graphisoft.com/viewtopic.php?t=21463
Peter Devlin
