HELP - How do I stop an 'endless' GDL script ?
Any replies within the next hour (I'm going out for lunch) would be MUCH appreciated ...
I am developing a GDL object and having written about 60 lines of code - and forgetting to 'save', I have accidentally 'previewed' the UI script. Unfortunately I forgot to block out a DO ... WHILE script and Archicad is hanging.
a) when will smoke start coming out of its ears?
b) how do I interrupt this?
TIA - Stuart
Try to open any other script. If the processor allows you to do that, then you can save your previous script. It works ... sometime.
Olivier;
I tried that too! ... but thank you anyway!
So, before we put 'Use Escape Key to act as a BREAK function while in the GDL scripting window' into the Wishlist, are there any comments?
- Stuart
PS. I gave up in the end. Only 1 hour wasted. I guess this was AC's NY gift
Aussie John
command period works on a Mac
Cheers John
[/size]
