‎2007-02-26 11:50 PM
‎2007-02-27 01:24 PM
‎2007-02-28 06:19 PM
Nathan wrote:To get the look and feel of this kind of model it may suit your needs better to look at getting them modelled in another program such as 3DS or Max. You might even find ready made models in DWG/DXF format. You can import the models to ArchiCAD.
Hi there,
We are lookingto get this chair modeled, and develop a relationship with someone who can produce high quality GDL objects.
We don't have more dimensions than shown, and making it look "right" is part of the deal.
Nathan
‎2007-02-28 09:17 PM
kliment wrote:Doh
If you want to model the crumpled leather too, then you will have to ask some Russian programmers - I have seen them model every crazy curtain you could imagine!
‎2007-02-28 09:41 PM
‎2007-02-28 10:46 PM
kliment wrote:Irrational fabric rumpling is easy, but requires a meticulous eye. This process requires NO GDL. Creating a rumpled surface requires manipulating a MESH, usually in 3D, to patiently add irregularities to a smooth, geometric mesh. Meshes have specific restrictions: they cannot overlap themselves, so to make a cushion requires mating two meshes with identical outlines but the upper mesh bulges upward and the lower mesh bulges down. Make the top mesh and bottom mesh have matching edge elevations by establishing the top mesh boundary nodes and then duplicating it. You'll also need to make ridges smooth in the mesh.
It is not very difficult to model this item with the AC.
‎2007-03-01 01:23 PM
