Have any way to convert ArchiCAD14 gsm to ArchiCAD13 gsm?
For example this archiCAD 14 gsm
15 Replies 15
Hello.
Could you explain how you "Extract the object from the Embedded Library to wherever you wish" ?
The extract part more specifically.
Roger
See the picture.
Frank Beister
But this should not happen very often.
@laszlo
You mean there are not so often improvements in GDL any more? 😉
@laszlo
No, actually what I meant was that for example if there is a new GDL command in a new version it does not mean that now there will be a lot of library parts using that command. More probable is that most library parts are just updated to the new version or if they are modified that will still be understandable by older versions.
So if a AC14 library part is converted to AC13 then in most cases it will still be understandable by AC13 as it will not contain GDL commands only AC14 understands but AC13 doesn't.
Frank Beister
Sorry Laszlo, it was an embittered joke.
Fact is, that GDL has not got no major improvements in the last years, that it brought up much better or new objects.
Oh, yeah, I should have known what you meant.
