2010-01-14 06:44 PM
2010-01-15 10:52 PM
2010-01-15 11:45 PM
2010-01-16 03:41 AM
2010-01-16 07:58 AM
Karl wrote:
What format objects are you downloading? dwg? 3ds? ...??? Answer varies.
2010-01-16 08:00 AM
Matthew wrote:
First make sure you haven't overridden the internally defined materials. Most 3DS (and even DWG sometimes) come in pretty clean with correct colors.
2010-01-16 08:03 AM
Steven wrote:
If the library part was written well, you should be able to go into the settings and change individual parts of the object to different colors.
If there is only one color option, someone was lazy... which may be the case. You may be SOL, unless you know GDL.
2010-01-16 12:58 PM
2010-01-16 02:37 PM
2010-01-16 06:51 PM
