Holes in Canted Walls?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2004-04-10
09:13 PM
‎2023-05-26
12:25 PM
Rubia Torres
‎2004-04-10
09:13 PM
How do we cut holes in canted walls for doors and windows?
Thnks
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-11 10:08 AM
‎2004-04-11
10:08 AM
Mica wrote:We do not I am afraid.
New here, got a quick question.
Thnks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-11 11:01 AM
‎2004-04-11
11:01 AM
Mica wrote:How are you doing the canted wall?
1. Wall Extras - API takes care of it, and makes the hole for any door or window placed in the original wall
2. ArchiWall - same
3. Walls trimmed with roofs/or SEO used (see previous topic and Dwight's advice at
4. Roofs acting as walls - no dice; you have to SEO stuff out. Tip: If you do make a canted wall with the roof tool, place doors and windows as needed in walls exactly the size of doors/windows, and then SEO these walls out of the roof. Should look OK in section, elevation and 3D, although the plan might need tweaking.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-11 06:57 PM
‎2004-04-11
06:57 PM
The SEO method remains the most adaptable since the actual wall and window combination are cut in place, not some tilted external skin that cannot support a window, the origin wall of which must be later hidden.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-11 07:02 PM
‎2004-04-11
07:02 PM
OF course, this method - since the actual wall is cut - allows for easy edits of window and window position changes while maintaining the cut angle.
Dwight Atkinson
