Horizontal Colorbond Corrugated Sheet
I am trying to get a model texture with horizontal colorbond corrugated sheet. The Australian library has the colorbond colours but the sheets dont show in Lightworks when they are rotated at 90deg (horizontal). The corrugated sheets in AC9 textures do rotate but there are only 2 colours and not the colours I want to use.
Does anybody have a work around to create this horizontal corrugated cladding. I would like to create the standard colorbond colours.
Any assistance gratefully accepted.
3 Replies 3
Dwight
To clarify:
a texture doesn't work in Lightworks when rotated 90 degrees?
what exactly happens?
how about 45 degrees?
can you post the texture map?
Dwight Atkinson
Hi Dwight,
I forgot to hit the button "Match With Internal Engine" in the Lightworks Materials Settings. Doh. Anyway it worked and thanks for the memory twig.
Dwight
Swell.
Users will note that Archicad 10 has fixed the texture flipping bug when matching the Internal Engine.
Or should that be the flippin' texture bug?
Dwight Atkinson
