Hotlinked object can't call macro
Hi.
I'm working with two TW projects. One which contains all door schedules and layouts. Two doors which are two different objects are shown as fuzzy dots in the door model which has the original TW project hotlinked into it. Both projects use the BIM library which is up-to-date in both projects. I get the following error message that refers to the master script of the door objects:
"can't find macro gs_general_lt_door_macro called at in line (...) in the master script."
I opened the master script of the door object and it looks like this:
So this gs_general_lt_door_macro is located in the standard lcf library. Anyone got any idea why it can't find it?
hit CTRL+SHIFT+O having selected the macro name:
if opens - it may mean that you have mixed libraries from different versions of AC. Even if the macro exists it will non be called with success if it called diffrent version of this macro when object was saved (internal GUID is different)
Best Regards,
Piotr
Piotr, I believe you were right. I added an older library and it worked. Thanks.
