Issue output/calling on global
Hi. I'm trying to edit the marker so that it displays the orientation after the ID on the floor plan but I don't seem to figure out how to call correctly on the WIDO_ORIENTATION.
I want to edit the 2D script by adding: + WIDO_ORIENTATION but it doesn't output left/right on the floor plan. This method works fine if I add a text or number for example: + "10" outputs 10 after the ID on the floor plan. Any idea on how to call on that door parameter?
Regards
Alex
0 Replies 0
