Hotspot2
B] Hi guys [/ b]
I'm new here too on the ArchiCad but I'm thinking That I wanna test out ArchiCad two see if it is possible two make a smart object so I can do work faster comp in ArchiCad than Revit.
I've seen some on this page thatthere are many experts in GDL here That might help me when I do not under stand so much of GDL script.
I'm Attaching a picture fom explain ocean I need help.
Also sent with the object I have made so far.
What am I doing wrong?
My problem is getting to hotspot2 so I can change the length of both sides of the plates and the cores. I hope it is something that can help me with it.
Thank you in advance
project2{2} 3, 270, 3+16
!Magnaboard
HOTSPOT2 0,0
unID = 1000
HOTSPOT2 AA,    0, unID, dmgo, 1: unID=unID+1 !!!POINT BASE
HOTSPOT2 AA, dmgo, unID, dmgo, 2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 AA,    0, unID, dmgo, 3: unID=unID+1	!!! REFERENCE POINT
DEL TOP
!Hotspot
HOTSPOT2 AA, dmgo
HOTSPOT2 tiso_y+0.010, diso_y
HOTSPOT2 tiso_y+0.060, dmgo	+0.020
HOTSPOT2 tiso_y+0.060,0.020
DEL TOP
!Exterior polystyrene core
unID = 2000
ADD2 AA, AA
HOTSPOT2 tmgo,     AA, unID, diso_y, 1: unID=unID+1 !!!POINT BASE
HOTSPOT2 tmgo, diso_y, unID, diso_y, 2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tmgo,     AA, unID, diso_y, 3: unID=unID+1	!!! REFERENCE POINT
DEL TOP
!Middle polystyrene core top
unID=3000
ADD2 tiso_y-0.065, BB
HOTSPOT2 tiso_m1,       0, unID, diso_m3, 1: unID=unID+1 !!!POINT BASE
HOTSPOT2 tiso_m1, diso_m3, unID, diso_m3, 2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tiso_m1,       0, unID, diso_m3, 3: unID=unID+1 !!! REFERENCE POINT
DEL TOP
!Middle polystyrene core middle part
unID = 4000
ADD2 tiso_y-0.065, DD
HOTSPOT2 tiso_m1,       AA,   unID, diso_m2,  1+256: unID=unID+1 !!!POINT BASE
HOTSPOT2 tiso_m1,  diso_m2,   unID, diso_m2,      2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tiso_m1,       -1,	  unID, diso_m2,	  3: unID=unID+1 !!! REFERENCE POINT
HOTSPOT2 tiso_m1,  diso_m2,   unID,      AA,  1+256: unID=unID+1 !!!POINT BASE
HOTSPOT2 tiso_m1,       AA,   unID,      AA,      2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tiso_m1,       -1,   unID,      AA,	  3: unID=unID+1 !!! REFERENCE POINT
DEL 1,1
! Interior polystyrene core
unID=5000
ADD2 AA, AA
HOTSPOT2 tiso_y+0.160,      0, unID, diso_i, 1: unID=unID+1 !!!POINT BASE
HOTSPOT2 tiso_y+0.160, diso_i, unID, diso_i, 2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tiso_y+0.160,      0, unID, diso_i, 3: unID=unID+1	!!! REFERENCE POINT
DEL 1
! Cement plate
unID=6000
ADD2 tiso_y+0.170, AA
HOTSPOT2 tiso_i,     AA, unID, dsem_p,  1: unID=unID+1  !!!POINT BASE
HOTSPOT2 tiso_i, dsem_p, unID, dsem_p,  2: unID=unID+1 !!!POINT OF MOVEMENT
HOTSPOT2 tiso_i,     AA, unID, dsem_p,	3: unID=unID+1	!!! REFERENCE POINT
DEL 1
David Maudlin
Laurits:
If I understand your illustration correctly, this can be done with GDL to create a custom parametric Object. GDL can be used for Objects, Doors, Windows and Lamps. It cannot be used for Walls, Roofs, Slabs, etc. So it depends on whether you want a customizable Object (yes) or a customizable Wall (no).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
