How can I call a zone's ID in a label tool
Erika Epstein
I am using James Murray's Shape Tag and would like to add a parameter to call the ID of the Zone that it is placed in. Is this possible and if so how?
I am trying to work around not having overlapping zones as this causes problems with schedules. And working around also not being able to have a zone tag display differently for different layer combinations. In this case I must have a round tag with the zone's ID.
Thanks,
Erika
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
6 REPLIES 6
Are you using the object or the label? I don't think you can label zones per se. An object should be able to know the zone name, number, category, etc using the zone_relations request.
Then it's a matter of putting that number string in TEXT2 statement instead of the object ID or custom string.
I'll take a look at it and give more details when I get some time.
HTH,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Erika Epstein
Hi James,
I am using your
Shape Tag JM9.gsm
To meet some local school district graphics guidelines I need to show a circle with the room number. I'm using zone for the room name and number on the plans.
Thanks for your help with this.
Erika
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Unfortunately zone_relations can't request zone id so I have used zone number instead when possible.
maybe this helps:
http://archicad-talk.graphisoft.com/viewtopic.php?p=116092&highlight=label#116092
Sorry for the delay. I hope this is what you want. Choose 'Zone #' for the Text parameter.
James Murray
Erika Epstein
IT works! IT WORKS!!!!
James your brilliant!!!!!
Thanks so much
I can't stop smiling
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
This object is so cool. I have been using it for about a year for tagging modules that I need to schedule --the tags get scheduled. Over time I made a few tweaks:
- a rotation-awareness option so that the tag can stay horizontal when the modules rotate,
- the option for making the text include a custom 'mirrored' flag when the module gets mirrored, and
- a minimal 3D existence so that the tags can be Find-Selected multistory in the 3D window for editing font sizes or whatever (this is currently not very elegant, I think I had made a previous version work without the line but I can't remember how).
