How can I explode objects into different parts?
Is there an option to detach the Window's Frame From the glass?
Or the door from it's frame?
Is there ani option to "Explode" an object?
4 REPLIES 4
TomWaltz
It would be really nice, but no. When you explode an object (door, window, etc), it just becomes lines, not the component 3D parts 😞
Tom Waltz
Dwight
Not directly. You can visit the element script and eliminate the parts you don't want, however.
For instance, with your window, once you have saved a new named version, with some minor GDL skill you can isolate and delete the glass....
Dwight Atkinson
ok thanks
Is that so? Rather disappointing! In VectorWorks, the result depends on the current view: if 2D-plan, you get lines (or polylines). If any 3D-view, you get 3D-components. (Intuitive? Yes and no.)
I have e.g. this (DYI) VW-object that creates pre-stressed hollow-core concrete slab elements as 3D Booleans. If I explode one in a 3D-view, the slab becomes a Boolean. I may then continue to explode it to simpler 3D-components and, eventually, even to view-dependent 2D-lines, but one step at a time.
With many other objects, you get a strange and incomprehensible mishmash of extrusions, sweeps, meshes and 3D-polygons, but 3D nevertheless.
Well, whatever. Such operations are rare and exceptional indeed. As long as the relevant conversions are handled transparently when exporting to another format, I'm happy. Good to know, nevertheless.
