How can i add transom to w ribbon 10 windows?
muzedesigns
Hello!
I am trying to build a series of window obects (or rather modify existing ones) to represent these windows.
I need fixed base with top hung awning BUT 3 ribboned or up to 4 at times..
As well as the opposite Fixed top with top hung transom..
I just can't seem to get it as one window with 3 horizontal sections.. and have bought a bunch of promising 'window building objects' that I fail to get work and only just end up with a bunch of code errors.
Any ideas or suggestions? : )
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
14 REPLIES 14
David Larrew
I don't know if you have this window object in the AC10 Library, but in AC11 (USA) there is "W F Casement Combi 11" that does what you are describing and more (without buying any non-standard objects). It is a single unit that, like all other GS windows, can be ganged together.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Hello David,
There is a "W F Casement Combi 10.gsm" in the AC 10 US library
but that is not the only issue here. The author of this thread is
located in Australia so is probably using the AUS version of the
AC library. I have learned in the past year or so that the various
localized versions of the AC library can be very different.
For example the "W1 Casement 10" in the US library is quite
different than the "W1 Casement 10" in the AC 10 INT library.
When I first saw this thread I was going to see what I could find
but then concluded that this was useless because I had a different
localized version of the library and hoped someone with the AUS
version would help out. My comment here is in no way meant
to correct you but to emphasize an issue with Archicad that is
becoming more serious every year as the localized versions diverge.
Peter Devlin
I do not find this object neither in my AC10 lib, nor in my AC11 lib.
Peter and David, could you, please, send it to me because sucha window is exactly what I need at the moment. I will send you my e-mail in PM.
David Larrew
Peter,
I've been told that GS is trying to "solidify" their varying Library versions due to previous comments similar to yours. I am always being asked to share the "USA" version of Library Parts. Hopefully the Object Depository will eventually be a good resource for GS to help support the varying legacy Libraries.
Only time will tell.
AC 5.1-25 USA
Thomas Holm
Andy Thomson is doing amazing work with the aim of consolidating a common global library, based on the INT, GER and US libraries of today (if I got it right). Unfortunately, at the moment there seems to be some problem with the website www.archicad.ca. Hopefully, Graphisoft will take action to fix this immediately - this work is long overdue!
http://archicad-talk.graphisoft.com/viewtopic.php?p=103346#103346
muzedesigns
The Aus Library is terrible at the moment.. It has little standard commercial items that I need and I find my self constantly buying new object which turn out having some sort of bug or preventing issue which renders them almost useless.. I find my self wasting more time looking for objects and trying to customise them than actually working.. I should probably do a course in gdl creation – but where would that time in the day come from!
Also the jump between the 9 and 10 library whilst impressive in the customability of some objects, left many other key objects behind..
I would assume as a program like this develops, objects should not get removed but replaced with better more efficient and easy to modify objects.
Would someone be willing to share this fantastic sounding window object with me by any chance?
Chrissy
Chrissy Avramidis
Chrissy,
Which fantastic sounding object do you want ?
The "W F Casement Combi 10.gsm" ?
If so, I can send it to you. All I need is your e-mail address.
Peter Devlin
muzedesigns
Alll of them.. just kidding!
If you could send the combo window that would be fantastic and greatly appreciated!!
I am at:
inspire@muzedesigns.com
Cheers!
Chrissy Avramidis
muzedesigns
Thank you kindly for sending me the direct glazed window object Peter!
Unfortunately, this object isn't fulfilling exactly what i require;
I can can successfully control the upper or lower transoms with top hung awnings accordingly, but i am unable to have multiple 'ribbons' of the window in a row.. I was hoping that i could have three identical windows (or more) in the one casement like in the "w ribbon 10.gsm"
My way around this now will be to use an old sill object to have one continuous sill across a 2700 with the additional 3 w direct glazed windows.. unless there is a more efficient and optimal way??
David: Does the version 11 combi object have that functionality? would it be possible to send it to me or will it not operate correctly in archicad 10?
Chrissy Avramidis
