How create dinamics grids?
Good morning! I just read your post ..... thank you for your answers! However, the matrix has a specific task: to repeat an object that has certain characteristics. Instead, we need a GDL object that performs two functions: to reiterate and Automatic resizing of wooden rods to calculate with absolute precision the length of each of these in wood grilled.
3 Replies 3
Erika Epstein
You either need to learn some gdl so you can create parametric objects and/or learn to turn custom saved objects into parametric ones.
Alternatively post an ad to hire someone who can make custom parametric objects for your firm's use. There are a lot of GDL experts who follow architalk who can help you.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Dwight
Many users can't get their heads around GDL, and besides, it has its heartbreaking limits. Instead, here's how to generate schematic trellises, fencing, ironwork, cheese steaks and screens using the complex profile tool:
1: Create a new complex profile containing fills describing the pattern. Start with a single fill surrounding one pattern void. Use the Multiply [matrix] function to array the pattern to the required size. Using incremental constraints will preserve the module.
2: Establish the material and SAVE the profile for use in Walls.
4: Draw the new complex profile wall perpendicular to the surface it will rest against - establish the thickness with the extrusion.
The complex profile has the advantage of quick edits and can produce any cutout.
Dwight Atkinson
