We value your input!
How do I inquire the size of the layout?
I want to inquire the size of the layout,
for making the drawing title.
for example,
A1, A2, A3...etc.
and
FIRST FLOOR PLAN A1 S=1/100
....................... .....A3 S=1/200
4 REPLIES 4
David Maudlin
TAI:
For the Drawing Title type, one of its parameters is AC_LayoutRect, which is an array that gives the extents of the layout the Drawing Title is on.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks for your help, I will try it out as soon as possible.
David Maudlin
TAI:
If you search the forum for AC_LayoutRect, you will find some threads about its use.
Thanks for adding the signature.
According to the following instructions, I understand how to use it.
http://selfgdl.com/9_diverse/globals/LABEL/kompendium.php?glob=AC_LayoutRect
But your hint is the key, Thanks.
