How do I set standard cabinet sizes?
We just upgraded to ArchiCAD 13 and I would like to set up my library so that base and wall cabinet sizes reflect what is out there for standard cabinte sizes. Base cabinets come 3'-0" wide with 3" units of variation in width, and the cabinet depth is 2'-0". The counter top overhangs 1" on the front and there is a 4" tall backsplash. Wall cabinets have similar parameters. How can I set this up so that I can grab a cabinet from the library without having to adjust all of the parameters each time? I copy and paste, but from area to area or project to project, it takes time I think the computer should be able to do instead of me. It would even work if the object keeps the settings from the last cabinet I placed.
What is the best way to set up the library of cabinets so I don't have to continually adjust the settings each time I pick a different cabinet?
7 REPLIES 7
Don't have AC13 but in AC11 I set up "Favorites"
Doug
Great idea! I had the "Favorites" pallette up on my right screen, but I had no idea what to do with it, So I read the book. Thanks for the idea!
Roger
Laura Yanoviak
We have a "Casework Palette" -- sort-of-a "Visual Favorites" file that can be hotlinked or merged into the project file. It has the most commonly used parts with parameters set to LSI specifications.
Rod Jurich
Laura wrote:
/... -- sort-of-a "Visual Favorites" file that can be hotlinked or merged into the project file./.....
Thanks Laura, I like the "Visual" part, great idea as I find the Fav list can become quite cumbersome.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Brett Brown
BIMfast takes visual favorites a step further as well. Fantastic tool
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Wow! Laura's "Casework Pallette" looks like a fantastic idea! How does one go about setting it up? Back to the book!
I am totally lost. What is BIMfast? Is it part of ArchiCAD 13?
Thanks for your time.
Roger
Brett Brown
rhendrickson wrote:
What is BIMfast?
archicad-talk.graphisoft.com/viewtopic.php?p=161780&highlight=bimfast#161780
