‎2005-02-19
12:54 PM
‎2023-05-24
12:11 PM
Rubia Torres
‎2005-02-19 03:08 PM
Douglas wrote:
When I moved my GDL scripts to v8.1, I found many parameters had been quietly added by AC. These appear in blue text in the editor and fill up the parameter window.
I can't find a way to get rid of them. (When one is selected, the 'Delete' button is inactive).
‎2005-02-19 03:50 PM
‎2005-02-19 03:56 PM
‎2005-02-19 04:04 PM
‎2005-02-20 10:16 AM
woodster wrote:it also ensures that you can change the same parameter from a variety of different objects in one go (should you wish) without affecting any of the objects' other parameters.
So for example, the variable gs_door_frame is used constantly on all doors rather than having the variable be gs_door_frame and door_frame in another door. It helps (I believe) developers of library parts, it assures continuity from one version to the next and makes it easier to create lists among other things.
‎2005-02-20 04:57 PM
~/archiben wrote:Ben:
