hpenbeoglu
How to Change GDL Defaults of Zone Stamp Object?
How to Change GDL (stFloor Covering) Defaults of Zone Stamp Object? You know it's like carpet, ceramic, etc. Also is it possible to connect these options to the properties so that there will be an easy & editable solution?
BIM Manager, Architect in the UK | AC11-AC27
Macbook Pro 16" 2.4 GHz 8-Core Intel Core i9 - 32 GB RAM - 512 GB SSD | MacOS 13.3.1 (a)
3 Replies 3
Open object and just fill this parameter and then save under different name.
Piotr
hpenbeoglu
Thanks, Piotr. But I don't know the exact place to fill and also I'm am a beginner GDL user.
If You want the static text - just type it.
The list possible to select there is the other story.
You should search for
values / values{2} "stFloor Covering".... and see what possibilities are there.
if there is just set of text strings then add Yours...if there is some matrix parameter with the names - then probably this matrix parameter is defined in master script.
Piotr
