‎2017-06-28
12:32 AM
‎2023-05-26
02:15 PM
Rubia Torres
‎2017-06-28 01:10 AM
paulmckean wrote:To fine tune your eyedropper setting, you'll need to access the Element Transfer Settings dialog box. To do this, just before "injecting" you'll see a floating text button which (by default) reads "Transfer All Settings". Clicking on that will get you there.
Hi, having trouble transferring window attributes from one window to another. Eyedropper is transferring the wrong elements for some reason. ?? Thx.
‎2017-06-28 02:40 AM
junior wrote:Isn't this an Archicad 21 feature?
‎2017-06-28 05:20 AM
Barry wrote:Yes, what I mentioned is an AC21 feature. I failed to read the OP's signature and the fact that his eyedropper is transferring the "wrong" elements led me to believe he had access to that feature.
‎2017-06-28 07:53 AM
‎2017-06-28 08:36 AM
paulmckean wrote:As I said the only parameters you can control not to transfer are 'Anchor Point', 'ID' and 'Properties'.
Yes, working on Archicad 20 here. Not seeing that option. Any other ideas? Thanks.
