How to change a rule?
DaniBaiana
Hi everyone,
can someone help me change or deactivate this rule? Picture in attach.
Thank you so much
ā€ƒ
2 ACCEPTED SOLUTIONS
cuba
I do not recommend it but it is possible.  (I suggest making  a custom windowopening :  https://help.graphisoft.com/AC/26/INT/_AC26_Help/040_ElementsVB/040_ElementsVB-294.htm )
Removing the rule:
Open the object (ctrl-shift-o), and in the parameter scrip add "!" in line 35 >> Values "openingArchHeight"
ā€ƒ
ā€ƒ
Apple M1 Max 32 GB Ventura
AC27
@DaniBaiana wrote:
But I have to ask why you don't recommend it and can I use this for all object with that rule?
You are altering a default Graphisoft library object.
You can now never update that object if the library gets updated, unless you make the same changes again.
Same will happen in the next version of Archicad, you will have to make the same changes to the object again.
Save it as a new object that you can load in your office library, along side the default one.
That way you will always have this amended object (that will have the changes you want but will never get updated) and you will also have the default object (that will get updated but won't have the changes that you want).
4 REPLIES 4
cuba
Removing the rule:
ā€ƒ
ā€ƒ
AC27
Thank you so much, it worked. But I have to ask why you don't recommend it and can I use this for all object with that rule?
Thank you once again!
Helpfull as always. Thank you so much Barry!
