‎2005-05-16 07:40 PM
‎2005-06-06 09:35 PM
‎2005-06-06 09:42 PM
‎2005-06-07 09:04 AM
‎2005-06-07 09:31 AM
[...] would be to use the dialog option in the OPEN command which would allow the mac user to manually select the file from a browse box and then remember the path.Maybe you can check out the right path in this way. Ask for the file in the dialog box and PRINT the returned value.
‎2005-06-07 09:36 AM
