2007-05-24 01:18 PM
2011-04-07 09:13 PM
SandorP wrote:There's no need to merge all the XML files into a single file to accomplish this. You can run a script across multiple files in a directory, and plenty of text editors will allow find/replace operations to be applied to multiple files.
Question: Is it possible to convert a library with it's full directory tree into one single xml-file (and back)? My goal would be to modify every objects in a library with a single stroke, using eg. applescript.
2011-04-07 09:51 PM
2011-04-07 10:33 PM
SandorP wrote:If you want to do a search and replace across multiple files, just use a text editor like TextWrangler (free application). You can perform a search and replace simultaneously across multiple files by using
It's the search-and-replace part I can't seem to grasp. Any clues?
2011-04-08 11:32 AM
