How to hide parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-01-17 11:37 AM
can someone help
thx a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-17 11:57 AM
You have to go to parameter script and use:
hideparameter "parameter_name"
You can also lock parameters, give them possible values.......
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-17 05:46 PM
IF parameter1 THEN HIDEPARAMETER 'parameter2'This says that if parameter1 is turned on, parameter2 is to be hidden. For this to work, parameter1 must be a boolean value.
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 12:13 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 12:16 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 02:57 PM
You will want to use an If-Then command, for example:
If Door_Type="None" Then HideParameter "Door_Mat", "Trim_Mat"
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 05:58 PM
Type_of_Desk choose between "Door" "Drawers"
But i have also a parameter Number_of_Drawer and Material_Drawers
and those parameters must be disabled when you choose "Door"
Can you please send me a script or something
I tried this in the parameter script
IF "Type_of_Desk" = "Door" THEN
HIDEPARAMETER "Number_of_Drawers"
HIDEPARAMETER "Material_Drawer"
ENDIF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 07:03 PM
You jumped over Erich's Comment.....
For your desk you need to create a Boolean value for the doors and or drawers. If the only two options are drawers or doors then try something like this (assuming you are using a VALUES script in the master script)
Parameters
desk_type Abc
desk_drawers Boolean
desk_doors Boolean
Master Script
dt_1 = "Doors"
dt_2 = "Drawers"
VALUES "desk_type" "Doors", "Drawers"
Parameters Script
IF desk_type = dt_1 THEN
PARAMETERS desk_doors = 1
PARAMETERS desk_drawers = 0
ENDIF
IF desk_type = dt_2 THEN
PARAMETERS desk_doors = 0
PARAMETERS desk_drawers = 1
ENDIF
Then you set up what parameters you want hidden or showing based on the values of desk_door and desk_drawers
IF desk_drawer = 1 THEN
HIDEPARAMETERS .................
ENDIF
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-18 10:18 PM
jensvs wrote:Given that your parameters are text (i.e. door or drawers) and not boolean, then what you show is fine, other than you have quotes around Type_of_Desk in your code.
ENDIF
You can even simplify this as follows:
IF Type_of_Desk = 'Door' THEN HIDEPARAMETER 'Number_of_Drawers', 'Material_Drawer' ENDIF
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-19 04:02 AM
The parameter list will remain unchanged - you can't tell what is hidden or not until you save the object and use it in Archicad.
A little trick I do though is to also 'LOCK' the parameters.
This you can see while you are editing the script - the locked parameters will turn grey in the parameter list.
IF Type_of_Desk = 'Door' THEN LOCK 'Number_of_Drawers', 'Material_Drawer' HIDEPARAMETER 'Number_of_Drawers', 'Material_Drawer' ENDIFBarry.
