2019-12-19 11:04 AM
Solved! Go to Solution.
2019-12-20 02:21 AM
REQ("GDL_Version")it's not possible to retrieve the current running language afaik.
2019-12-20 02:21 AM
2019-12-20 11:10 AM
2019-12-20 01:04 PM
2019-12-30 07:04 PM
Piotr wrote:Oh yes, sure! It actually makes a lot of sense nowadays! 🙂
Id does make sense - say preparing the multilanguage library for the manufacturer of something.
2020-01-27 11:13 AM
runxel wrote:Okay, so listen: Great news! I was wrong.
<productversion> <buildnumber>2800</buildnumber> <projectbuildnumber>4010</projectbuildnumber> <codename>v2019</codename> <versionstring>23.0.0</versionstring> <shortversionstring>23</shortversionstring> <platform>MAC32</platform> <gslanguage>GER</gslanguage> <gsprodtype>FULL</gsprodtype> <prefspostfix>v2019 GER 2800.4010</prefspostfix> <guid>{6108D34D-A54F-49CE-A83C-9B805F956D74}</guid> <supersedes-lib name="BIBLIOTHEKEN 13" guid="{09C93C26-1CA0-11DF-B83D-B3B556D89593}"/> <supersedes-lib name="BIBLIOTHEKEN 14" guid="{988B0D68-1BEC-11DF-BC14-569455D89593}"/> <supersedes-lib name="BIBLIOTHEKEN 15" guid="{B559A49C-53AC-11E0-892A-2609DFD72085}"/> <supersedes-lib name="BIBLIOTHEKEN 16" guid="{736BF948-34A6-460F-8BE2-80AF101776B5}"/> <supersedes-lib name="BIBLIOTHEKEN 17" guid="{2DDCC60A-4E34-4DCC-8A21-C099C89DC870}"/> <supersedes-lib name="BIBLIOTHEKEN 18" guid="{BECC7064-F02C-4F35-91D0-613E6BD8D5DA}"/> <supersedes-lib name="BIBLIOTHEKEN 19" guid="{882FD682-7057-4C18-A761-40544EB588AD}"/> <supersedes-lib name="BIBLIOTHEKEN 20" guid="{FF6B2803-AC38-48C2-ABD6-6D56DD453444}"/> <supersedes-lib name="BIBLIOTHEKEN 21" guid="{7A18EB31-3044-4E99-8F54-B6CB16B6CE88}"/> <supersedes-lib name="BIBLIOTHEKEN 22" guid="{C46B01B7-097F-4F18-9B3D-71413F211E37}"/> <collapse-branches/> </productversion>What's interesting here is the 'gslanguage' part: since users can't (and mostly never even attempt) to load a library not in their native language, we can utilize that to see what language the user expects.
! [MASTERSCRIPT] ! declare all the variables we need _dummy = "" ! only there so it can be ignored… pos = "" nodename = "" nodevalue = "" nodetype = "" err = "" errex = "" ! first we need to open the file !< `ch` stands for 'channel' ch = OPEN ('xml', 'ARCHICAD Library.version', 'rl') ! | | └ the file name |└ Locally loaded ! | └ add-on type └ Read-only ! └ open command: the file we want to read ! returns new position descriptor (i.e. root of the xml) <= pos r = INPUT (ch, "NewPositionDesc", _dummy, pos) ! | └ command to exec | └ 'pos' stores the position from which we read ! | └ gets ignored, but must be set ! └ channel we want to read ! now lets move into the tree ! lets find the "gslanguage" node first rr = INPUT (ch, "MoveToNode FromFirstChild g* ELEM 1", pos, nodename, nodevalue, nodetype) ! | | | | └ will be "ELEM" ! | | | └ value will be empty at this time! ! | | └ nodename will output "gslanguage" ! | └ input the position from which we want to start ! | / BUT also changes/mutates the position of the descriptor! ! └ This command means: ! / Move to a node ! / starting at the first child node from the current 'pos'-node ! / now get the _first_ "ELEM" (element) ! / which starts with "g" ! We still didn't got the actual value ! ("nodevalue" was empty, because at this point we don't know what's inside, we just moved to the node) rrr = INPUT (ch, "MoveToNode FromFirstChild * TXT", pos, nodename, nodevalue, nodetype) ! basically the same as above, but this time we want the TXT (text) of the node ! we can omit the "1", because that's the default anyway ! you can use 'GetLastError' after every 'INPUT' command and see, what's wrong e = INPUT (ch, "GetLastError", _dummy, err, errex) ! | | └ error message (textual explanation) ! | └ errorcode, =0 if ok ! └ gets ignored, but must be set ! close the channel (i.e. the file): CLOSE chAll this stuff is needed, because GDL as BASIC based language can't really work well with structured markup like XML. If you would need more data, you would work with loops.
2020-01-27 12:40 PM
