How to locate the source object of a 3D "Warning!" message.?
I've opened an old AC12 project in AC16, consolidated the libraries, etc.
However, I get 3 "Warning!" messages stating "Normal vector and edge 317 is not perpendicular in pgon 142"
How do I find out which object, or objects, are causing the problem?
Dwight
By isolating divisions of the project using the marquee, then further subdividing until you isolate the problem elements.
You can also use the "Select all" function to pick all walls, slabs, etc, to isolate the trouble element category.
Dwight Atkinson
rocorona
If the error message reports an ID, you can use it with the "Find & Select" command (provided it's not a macro object called from another)
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
