m_ziolo_86
How to make an imported 3ds model a solid element.
Hello,
I've recently started using rhino as a program for modeling more complex objects for my designs. Archicad's goodie plug-in to import 3ds models works fine, but all the models are only mesh/surface type and I am unable to make any solid operations on them. I made research on forum on already know that tehere is a possibility to add "MODEL SOLID" line in GDL 3d script of an object. However, it doesn't work. Even though gdl script is written correctly and i don't get any error messages, there is no respond in change of objects geometry. It is still only a surface. Is there any simple method to solve this problem ?
Archicad 16, Win 8.1
i have the same problem with autocad and microstation
as attached pic if anyone has a way to solve this issue please advise
