How to make u supertotalcustom window?
MarinRacic
I've been going through the Total Custom Window tutorial - the one that deals with editing GDL script into making a completely custom free-shape window.
My question is: how can I make a window in a shape of a ring, not a circle? Like letter O or D? I've tried the tutorial method, but I get strange results - check the attached picture.
What am I to do?
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
2 REPLIES 2
When you create WALLHOLE element cut it for two piecec without holes. Then for each one use WALHOLE. WALLHOLE command can be used for elements without holes.
MarinRacic
Thanks, that did the trick!
AC ...20/21
www.3Dart.hr
