2023-04-19
01:13 PM
2025-02-10
05:14 PM
Aruzhan Hamar
There is a post asking the same question, but this is from 2010, and I can't follow the steps in the answer. I want to select all the objects in a specified layer, which may contain multiple types of objects. How do I do this for Archicad 26?
2023-04-19 02:21 PM
Click on the arrow next to "Section" and set it to "All Types". Click the "Add..." button and add Layer as another criteria.
2023-04-20 09:31 AM - edited 2023-04-20 09:33 AM
I'm assuming when you say "objects" you mean literal ArchiCAD objects. First, select one of the objects that you know is on the layer you want to use as the criteria. Then click on the eye dropper tool (highlighted in light-blue above). Then under "Element Type" change it to objects. Then click the "Add..." button and choose layer. By having previously sucked up the settings of your selected object, the layer should already be set. Finally, hit the "+" button and it will select all "objects" on a given layer.
