How to skew something (via XFORM)
Apologies to Katarina:
Her thread was sort of hijacked into a discussion of XFORM, so I have copied it into the GDL forum for further discussion of XFORM. Her original question on walls should be answered in the remaining thread in Working in ArchiCAD:
http://archicad-talk.graphisoft.com/viewtopic.php?t=26825
Sincerely,
I am trying to create a wall that is slanted in two different directions, see the picture, but I haven’t been able to figure out how to do. I have looked at the complex profiles tool, but I have only managed to create a wall that is slanted at the same direction in both ends, not in opposite directions.
Anyone who knows how to do?
Regards,
Katarina
22 Replies 22
Oleg Schmidt is the one who suggesting skewing as a practical use of XFORM:
Subject: 	[GDLTalk] Re:  XFORM (was koordinates)
Date: 	July 13, 2001 1:33:04 PM MDT
To: 	Karl Ottenstein
Hello Karl,
This is great explanation, Karl !!!
KO> !
KO> ! This is probably not that useful for most GDL programmers
There is one opportunity which I really used in GDL practice.
It something similar SKEW. It is possible to achieve a skew in various directions.
For example:
ang=30
XFORM 1,0,0,0,
      0,1,0,0,
      TAN(ang),0,1,0
CYLIND 0.5,1
DEL 1
Thanks, Oleg
PS Glad to see the Yahoo GDL Talk messages are still present there:
http://tech.groups.yahoo.com/group/GDLTalk/messages
I never visit that forum any longer, since we have had a GDL forum here ... but I see it still has activity. I would prefer that everyone post GDL issues here, so that content is focused in just one place.
Hello Karl,
Your post to Laurent has the explanation text and the
math references I remember from your object but as
you say the code is not exactly the same. I suspect
that after your post to Laurent you decided to make
the lib part I described but I don't know how you made
it available to others.
Thanks Karl,
Peter Devlin
