Zendrix
skewed staircase
Hi
How would i go about to design this skewed simple concrete staircase, considering some steps are not paralell, and also some steps are wider than others?
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
CosminF
You could try playing around in 3D in edit mode (similar to curtain wall feature), and treating the asymmetrical stairs as landings so you can modify their width:
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
cuba
It is possible to select the stairs on two sides.  One side with the bleu refence line, the other side with two green lines.  With the greens lines you can adjust the shape of the stairs.
Apple M1 Max 32 GB
Latest AC
